in tank fuel pump dead
sloryd
Houston TX.
One truck has a dead fuel pump. Where can I get a replacement?
I want to place with intank unit. I was reading in other posts, but they were old posts, that Olympic sells new ones. Does any have a contact or is there another resource available.
poppop
39
Brooklet, Ga
Have you checked it out completly and know for sure its dead?? There is a post just back a little ways talking about fixing the in tank pump. I have fixed two in the last two weeks and have not had to install a new pump yet. A lot of times it is bad connections that keep it from operating.
Jinx
Buy me a Coke
124
Gainesville, Florida
I only bought one. The guy needed some photos of the original pump to match up the replacement correctly. Cost was ~$225.
sloryd
Houston TX.
Pretty sure the pump is dead. Took the unit apart and check with an Ohm meter and shows an open circuit even if I rotate the motor.
Thanks for telling me to take the pic of the pump before I call Olympic. I have found 2 used ones that are be shipped to me now. But I would like a new one.
sloryd
Houston TX.
Got my pumps on friday. Olympic control is a great bunch of guys to work with. Highly recommended and very helpful. Thanks for letting me know about them.
halftrack43
Lake Grove/NY
Did you check power to the pump yet?Check it at the connector on top of your tank, then remove the Fuse block (square block on top of the tank has a glass fuse it it) They always corrode badly. If it is rome the block a take a small wire brush and burnish all the connections and clean out all the rust you can. 90% of the time it's that Dam fuse block. They are hard to find in unused condition. Check it out! You'll hear it hum if it works.
