tsmall07
- 4
- 0
- Springfield, VA
**Update at the bottom**
So I finally got this thing running again after about a year. I had to replace the fuel pump and had other things going on and was gone for the whole summer so I didn't get it done. I wired in an electric pump to replace the mechanical one a few days ago. The truck ran fine before I let it sit for a year.
I got it inspected and took it on its first decent trip since I got it running (90 miles round trip). The truck seems to surge and drop off as I drive. It's not enough to really change my speed, but enough to be noticeable. Twice after a stop, it acted like it was going to shut off (no throttle response) and once it did shut off as I was coming up to a stop. It started right back up again after the shutdown. I bought a new main fuel filter, but I don't really know how to do it. Is there any way to drain the filter before you pop it off? I tried unscrewing the thing on the top, but all the fuel just ran out the drain to the side of it.
Could this problem have anything to do with the trans? The shifter lever is very inaccurate and it is hard to get it in the right position.
What could happen to the truck while it's sitting to make it behave like this? (please don't say I need a new IP... )
Edit: M1008, btw. Don't kn ow if it matters.
