rtrask
- 225
- 43
- San Luis Valley, Colorado
SEE HMMH HME Owners
The number under the topic is the post number, to convert to the page divide by 20 and add 1 to the value.
So for example: for discussion on fabrication 9/20 = 0 + 1 or page 1
for NAPA oil and fuel filters 31 / 20 = 1 + 1 or page 2
Please contribute!
Discussion on fabrication
9
Air leak when putting in 4 / 4 diff lock (air diffs)
28, 32
31
Picture of jack for removing the front end loader
58 (official) 61 (home grown)
Picture of cab tilting brackets
66, 69
Advice on removing front end loader and backhoe
71
Pictures of tilted cab
77
Pictures of front end loader bucket controls / source for replacements
88, 90
Dashboard electrical problems
92, 237, 462, 472, 477, 489, 497, 526, 540, 569
Front loader removal
102
Getting backhoe to lock
108, 112, 341, 345
Air Hose source
110, 1195, 1201, 1207
Ripper for backhoe
119
PTO / Hydraulic lever and high RPM
133, 142, 144
Alternator Wiring
147
Slow leak in fuel supply lines / fuel starvation issues
151, 155, 159, 2643
Master disconnect and key issues
209
Stuck in neutral / clutch issue
245, 253
Vtwin4christ videos
324
Airbrake discussion
326
Tips on grading
351
Backhoe is 580C case cylinder rebuild discussion
366, 374
Spare Tire
369, 371
Auxiliary hydraulic quit working
426, 427
Power to the starter === power to dash
449, 451-453 462
Specs on Hydraulic Flow
457
Replacement for cooling fans
482
Stuck nuts and paint
491
Fuse block replacement
502, 503
Engine Anti Freeze
536, 539
Replacing work lights with LEDs
573
Cracked injector & drain coolant
599
Ideas on suspension lockout
600
Non gov fluids
641, 643, 644, 656
Removing backhoe
649
Snow blower
692, 707
OEM Auger
722, 726
Air hose, reel
724, 734
Brush Hog
742
Replacing Batteries with group 31 optima
749, 757, 759,1568, 1570,1571,1573,1574,1584 -1587
Air locker drain
796, 846, 848, 849
Air leaks
797, 904, 908
Engaging PTO without grinding
803
Tires, pressure, bouncy handling
829, 831, 954-956, 987
Mixing Hydraulic oil
851
Electrical issues -- Air brakes -- Compressor -- Starter
858, 860
Fuel prime issues
863, 871 - 873, 949, 951, 953, 954
Backhoe thumb
914, 922, 927, 928
Electrical Relays
944
Split shift issue
1046
Fuel starvation
1117, 1121, 1123, 1136
Boots on tie rod ends --
821,1160, 1173, 1181, 1182, 1189,1197,
https://www.benzworld.org/forums/un...t-repair-finally-great-way-2.html#post2301459
https://www.energysuspensionparts.com/universal-dust-boots.asp
http://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
Diesel bug growth
1161, 1175, 1179
Rear work lights / back up
1185
Either Cylinder
1231
Using a winch
1238
Spare Tire Lifting
1376
Red-River-Army-Depot-(RRAD)- rebuild
1393 http://www.kmimediagroup.com/milita...-7-issue-1-february/6421-vehicle-reset-sp-535
1395
https://www.steelsoldiers.com/showthread.php?104940-Red-River-Army-Depot-(RRAD)-rebuild
Discussion about HHM suspension lockout between Flu Farm and Big Bison
1403-1471
Water/Oil/Engine heater
1411,1415,1420,
Biodiesel
1442
Ripper
1472,1473,1476,1478
Digging with your SEE
https://www.steelsoldiers.com/showthread.php?116544-Digging-with-your-S-E-E
1473
Tires
1481-1484
Hood discussion
1530 - 1536 3788
Tire pressure Stencil
1620
Putting the front end loader in Float
1658, 1664
Oil Dipstick Length
1670, 1671
Fittings for hydraulic tool
1676-1679
Merits of regular backhoe vrs. SEE
1690
Discussion on batteries 2 12 volt vrs 1 24 Lithium & AGM, Lead acid
1700 - 1705 1716 1725
Alternator modifications for Lithium Battery 1748
Diagnosing fuel supply issues
1770, 1774-1777 2711
Issues with Tach and other wiring
1817, 1823, 1825
Discussion on SEE diagnostic wiring
1847
Weight of SEE without front end loader and backhoe 9740 lbs
Bleeding the brakes and other info
2641
4x4 diagnosis recommendations
2656
Ideas for lifting front tire(s) without a jack
2681
Recent acquisition of new SEE advice / tips
3788
Rebuilding Hydraulic rams
3762-3770 3792 3823 366, 374
Front bucket lever issues
3793 - 3800
Removing FOPS without additional crane or hoist
3805
Malone Specialty
3826
Please contribute!
9
28, 32
31
66, 69
71
77
88, 90
102
108, 112, 341, 345
Air Hose source
Ripper for backhoe
119
133, 142, 144
Alternator Wiring
147
151, 155, 159, 2643
209
245, 253
Vtwin4christ videos
324
Airbrake discussion
326
Tips on grading
351
366, 374
Spare Tire
369, 371
426, 427
449, 451-453 462
457
482
491
502, 503
Engine Anti Freeze
536, 539
573
599
600
Non gov fluids
641, 643, 644, 656
Removing backhoe
649
Snow blower
692, 707
OEM Auger
722, 726
Air hose, reel
724, 734
Brush Hog
742
Air locker drain
796, 846, 848, 849
Air leaks
797, 904, 908
803
851
858, 860
Fuel prime issues
Backhoe thumb
914, 922, 927, 928
Electrical Relays
944
Split shift issue
1046
Fuel starvation
Diesel bug growth
1161, 1175, 1179
1185
Either Cylinder
1231
Using a winch
1238
Spare Tire Lifting
1376
1395
1403-1471
1411,1415,1420,
Biodiesel
1442
Ripper
1472,1473,1476,1478
1473
Tires
1481-1484
Hood discussion
1530 - 1536 3788
1620
1658, 1664
Oil Dipstick Length
1670, 1671
1676-1679
1690
1817, 1823, 1825
1847
2641
2656
2681
3788
3793 - 3800
3805
Malone Specialty
3826
