I have a ton of documentation on my M1008, but no operator's manual, unless it's hidden someplace and I haven't found it... I'd like to have a picture of the panel with little arrows pointing at all the indicators. I'm not even sure what I'm supposed to have and whether or not they are working. Let me list what I think I know I should have, and you guys can let me know if I missed anything:
1) 4WD indicator - easy to check
2) Low oil pressure - turns on with the key, then goes out when the engine starts
3) Generator lights - these start out on then go out when I rev the motor
4) Glow plug "wait" light - obvious
5) Water in fuel - turns on with the key then goes out, does that mean it's working?
6) Voltmeter - mine doesn't seem to work
7) Low coolant? - I don't know where this is or whether it's working
Coolant temp indicator - must go on when it gets too hot? I don't know where this is either
9) Brake prop valve - don't know where this indicator is either. I can tell it's not hooked up though
Anything else?
Anything else?
