Inexpensive current & frequency transducer?
SteveH
Connecticut
Anyone found an inexpensive frequency/current transducers? This is to hook into my Autostart PLC so I can monitor the MEP remotely while it's running.
There's various frequency transducers on ebay, but they're large, and not inexpensive (also outputs don't really match the 4-20ma or 0-10v I'm looking for). It kind of hurts to pay anything more than $20 when that's the price of the Hardy Frequency/Voltage meter (and there's several apparent clones that do current/voltage/frequency for the same price). I'm even considering buying one of these to see if it can be modified...
Thanks in advance
Steve
SteveH
Connecticut
Re: Inexpensive current & frequency transducer?
This search on eBay turned up a few in the $50 to $100 range for frequency transducers. For voltage, http://www.ebay.com/sch/i.html?_odk...TR0.TRC0&_nkw=voltage+transducer&_sacat=12576 returns items as well, and they are less expensive.
Yes.... Those are the prices I'm seeing. That's going to come to around $150 to $250 to get all three parameters into the PLC. Seems high when I can get a LCD meter and current loop to do nearly the same thing for $20
PeterD
Jaffrey, NH
If you are willing to 'roll your own' then why not just build them? The voltage is a simple A-D converter. For frequency, a tachometer circuit would work just fine. I could do both for perhaps $20 in parts... And, who knows, maybe you can adapt a HF $4.95 DVOM to do what you want easily!
SteveH
Connecticut
What are you looking for in current sensors? I may be able to help out.
Looking for a pair of transducers to mount below the lugs in the distribution box, one to measure each leg (so at least 0-50A, preferably a little higher). These will interface to the PLC, with either a 4-20ma or 1-10v signal (I've got both options).
I did get a Paladin frequency transducer last night on ebay - $100 (ouch!), and as PeterD says, voltage isn't too difficult.
Realistically, this is all 'nice to have' (as I haven't yet worked out a way to control frequency), but I thought it would be good to monitor and alarm (email/txt) if there's any issues during the monthly test run
-Steve
PeterD
Jaffrey, NH
There are already current transformers and a monitoring circuit (the meter mostly) already in the MEP. Consider the potential of tapping off that existing circuit to feed your PLC.
SteveH
Connecticut
Yes - I'm also looking at that (trying to find out what the currents through the various meters represent), though that still doesn't give me the 'split' across the two 110v legs.
Steve
