INI Power Systems IG1000-ICMF Portable Generator Set
Ry2000
Cumming Georgia
Does anyone know about the INI Power Systems IG1000-ICMF from gov planet or specifically where to find the circular three pin bayonet locking ring plug that generator uses.
Or if I could convert the original three pin locking ring plug to a regular 120v outlet?
Any information would be greatly appreciated.
kloppk
4,171
Pepperell, Massachusetts
The circular connector will have a part number on it. Might need to get to the back of the connector to see the PN.
Yes, one could likely swap out the circuit connector and wire up a conventional 120 outlet and mount it somehow.
They did make some models similar to that with normal 120 outlets.
I have a PDF copy of the Operators and Maintenance manual. I'll send you a PM since you can't PM yet.
