LOGGJAM
- 0
- 0
- Lehighton PA
Hello All, my name is Mike and im from PA, i just became a member a few days ago...
I have recently bought my first MV it's titled as a 57 REO M35 and i have all the problems worked out except one and that is a fuel leak which i cannot seem to find where it is starting from it has a Hercules multi-fuel with ~580 hours on it, the the leak appears to be comming from somewhere on the hydraulic head of the IP but it does not leak while idling or on fast idle, it will only leak when engine is under load, i can run it through the gears once, stop and check and the IP will be wet with fuel, there is a 12 point 7/16 plug (at least i think its a plug) on the side of the hydraulic head which could be where the leak is comming from because the fuel on the IP is not any higher than that point, it doesnt appear to be leaking from any of the lines...
any ideas would be greatly appreciated, ill try to get some pics up soon...
