Injection pump oil hose
FLYWHEEL
Daventry Northamptonshire U.K.
Hi,
I am trying to find the part number for the oil line that feeds the IP, I've done several searches but cannot find the part number.
Also if anyone out there has replaced one can they point me in direction of someone who stocks these,
many thanks
FLYWHEEL
Ip.jpgHi gringeltaube,
thanks for your reply but the one you have found is the same one that I keep finding, the one I am looking for runs from the side of the block to a connector on the bottom of the IP and then connects to the hose that you have listed
gimpyrobb
dumpsterlandingfromorbit!
27,786
751
Cincy Ohio
I had some new ones made up a while ago. Send me a reminder tomorrow and ill see if I have any left whenI get home.
gringeltaube
Staff Member
2,517
Montevideo/Uruguay
View attachment 687120Hi gringeltaube,
My bad; misunderstood.
I'll try to look into it, later on.
Although it seems that you already found a possible source... Thanks Gimpy!
frank8003
4,984
Ft. Lauderdale, Florida
Is the lube oil line the small hose at the center of this picture?
This photo is for the fuel hose but this post is about the oil line, right?
I remember I bought some on SS but there is two and I could get to only one of them...
gimpyrobb
27,786
751
Cincy Ohio
Yes, that is an oil line. The O.P. has that one, but the lines I have made are in sets. One is from the motor block to that Fitting and the other is the one in your pic.
gimpyrobb
27,786
751
Cincy Ohio
5here wasn’t enough material to have all 10 sets made. I will post a classified after I hear back from the OP. I will probably have the rest by next week.
