KaiserM109
- 4
- 0
- SE Aurora, CO
I would like to find a TM that shows the INSIDE of an injection pump on a 1966 M109A3. The engine is an LD-465-1 without a turbo (See photo of data plate).
As I remember it, working inside the IP is a depot level job and apparently is not included in any TMs that I can find, including the ones that SCSG-G4 sent me on the thumb drive.
My problem is definitely RPM related and not fuel flow related. When it is cold it runs fine, but as soon as it warms up it begins “sticking” at 2100 RPMs. The symptoms are identical whether it is under load on a hill or sitting in its parking space in neutral. As it gets warmer it starts “sticking” at 1700 and 1800 RPMs. After a while it will not go past 2200, even with the pedal floored.
I have bypassed the FDC properly and that made no difference. I have taken the FDC and the part directly under it off and inspected and cleaned it; no change.
It ‘feels’ like something gets sticky when it warms up and it seems to me that disassembling it and cleaning it ought to work, but I would like to read a TM on the subject before I dive in.
If anyone has had this problem too, please let me know what you did about it.
Arlyn
Arlyn
