Erik Jenkinson
- 8
- 18
- Metairie, LA
My m1009 has been smoking slightly at startup(white) and under a heavy load smokes black. Under normal use it does not smoke at all. I believe I may hear a tapping coming from the ip. I also noticed that the other day the motor turned an extra crank or two after I killed the ignition. I cleaned all the electrical connections at the ip then, and this seemed to remedy the problem. I have done one heck of a lot to this truck, all thanks to this site. I am confident the tm can get me through an ip remove /replace. Are my symptoms ip related? I know a tapping ip is no good! It does seem to have no real loss of power however. Somebody give me a jumping off point. I need to get this thing figured out.
