Injection pump
dustinwynn
cement ok
Will a Continental LDS-456-1A multifuel injection pump interchange with a White multifuel?
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
You want to match up the advance unit. Its the 4 bolt tab under the "T" that goes into the hydraulic head.
gimpyrobb
27,786
755
Cincy Ohio
Don't forget to pull the shut off cover and verify the red/scored tooth is visible.
Visible, but not lined up with the arrow. I made that mistake when I first started tinkering with these trucks. The arrow is ONLY to remove the hydraulic head.
