helofire
- 0
- 1
- Chesapeake, Va.
Anybody recommend the best place to get the injector hard lines? Also best recommended brand for a complete gasket set for 6.2, Felpro or Sealed power? Vehicle is an 84 Blazer CUCV. Thanks.
RickI must have compromised several hundred interior coatings. I replaced many valve covers and gaskets with the intake in place. I would know of no way that a coating could be applied inside the lines. Not say they didn't do that but I see no need for it. And as long as they are not rusty used ones are just as good as new ones in my eyes. Good Luck. Sorry for all the bent fuel injection lines. But NOT really.
To all you non-believers;[QUOTE="dougco1, post:
I know it's true. I read it on the internet.
C’MON MAN !!!!!!
To add to this for the OP helofire. Accurate Diesel advertises new 6.2-6.5 injector linesIf you are rebuilding your engine or replacing your pump, now is a great time for new lines - injection lines do occasionally rupture and can leave you stranded. Trucks in northern states usually exhibit very rusty and pitted lines further worsening the situation. Failure to install all of the anti-vibration clamps can also lead to early failure. Diesel injection lines that have been bent during service can flake internally causing repeated fouling of fuel injectors.[QUOTE/]
