injector help
bbf
port st lucie fl
i have a 250 cummims and i am trying to find witch type of injector is there the numbers that i pull off the motor cummims cant match there are 2 sets of number on the plate witch are 11160 and the a SO 57707 . i would like to know if it is a top stop add or dial inc
any help would be helpful
WillWagner
2,574
Monrovia, Ca.
Use the torque method. Adjust the injector first, then the valves on the same cylinder. Torque them to 68-72 in. lb. Easy way to tell if you have top stops or not, is to look down at the injector. If you can see the spring, you have a non top stop. If all you see is the flat top of the plunger, you have a top stop. You can set either injector using the torque method. Small cam engines like it that way.
Gamagoat1
Kiowa, Colorado
bbf
Here is a picture of the top stop injctors. Looks like a castle nut on top. The non top stop has nothing but spring.
I've done mine like Will sugests and it works great.
