jterry211
- 0
- 0
- Houston/Texas
Hello all quick question.
My injector pump throttle shaft started leaking so I took out the intake and took off the top of the pump.
When I took off the top the fuel level was way below the throttle shaft like almost empty.
Is that normal?
I filled it up with fuel and didn't see any other leaks. And yes the shaft seals were toast. Ordered rebuild kit just wondering about that fuel level. Also it was running fine minus the leak.
Thanks,
Jason
Is that normal?
![](http://uploads.tapatalk-cdn.com/20160106/f4448b02c7961e95da67610e3581ccd2.jpg)
Thanks,
Jason
