I am trying to set the injector pump timing on my 003a and am having trouble. If I turn the engine clockwise while on the blower end and watch the valves for #1 cylinder (the cylinder on the blower end) the exhaust valve closes and just before the intake valve opens the PC mark is lined up with the pointer on the flywheel. The manual makes me think the pc mark should be on the compression stroke and not on the intake stroke. If I set the timing with the procedure in the manual I will have the fuel injecting right when the intake valve opens. I have attached pictures of the flywheel marks that my genset has (The PC mark didnt show up in the picture but the marks above and below it are visible). After rotating the engine clockwise from the PC mark I see an A and then a bunch of random marks and then a B.
What am I doing wrong here guys? Also, thank you in advance for any help.
