Injector Seals
67
Landenberg, Pa
I just about finished the Head gasket job on my '68 M35A2 and found that two of the orange rings at the tops of the injectors are bad. The ring between the injector and the head. They are puffing in and out with every compression stroke and I need to replace them too. Does anyone know where I can get these new?? I have a spare motor out back so I could swap out some of them but for piece of mind I would rather get new ones if possible. Thanks for any and all info. Also while I am at it I will be needing a new tach cable if you can tell me where to get one of those too. Thanks again.
Kenny
Keith_J
1,318
Schertz TX
The copper washers? They should be standard Bosch. Do you know the OD of the nozzle and thickness of the old gaskets? They are probably the same as the Dodge Cummins or VW TDIs which use Bosch injectors/pumps.
If you are in a hurry, you can flat sand both sides, then heat them to glowing to soften (anneal) them. They should seal but check the seats inside the head.
WillWagner
2,607
Monrovia, Ca.
They are much bigger than the ones used on the B or C. Try Memphis.
scooter01922
42
Newbury, MA
Not the copper washers, i know what he is talking about as i need some too. They are rubber and sit at the base or the collar on top of the injector. They seal the top of the hole the injector sits in. Bright orange in color on any deuce i have seen.
67
Landenberg, Pa
Actually I believe that it is the copper washers at the bottom that I am goin to need. I think the rubber on top is to keep dirt and moisture out of the injector port. Someone feel free to correct me if I am wrong. So anyone know where I can get some new copper washers??
WillWagner
2,607
Monrovia, Ca.
The orange seals are for keeping dirt, mud, bugs, rat turds and such out...you are correct scooter! The seal washers are for sealing the compression and for giving the nozzle the correct protrusion into the cylinder. Memphis, Antelope Valley and others will have them.
