Injector Washer Sizes
Rangie
Scotland, UK
Hi Folks,
Does anyone have a packet of #14025557 Injector Washers handy?
I'd like the O/D, I/D and nominal thickness please.
Can't find the info in 20, 34/P, GM52D etc.
Going to pull a couple of injectors to check them (running on 7cyl at idle), I'd like to have a few washers spare.....
Alec.
Jozseph
New York
Hi Folks,
Alec.
Alec,
The washer cost aaround $1.50 each in the US. A stock item.
You are aware new washers should be use each time you remove/install/reinstall an injector.
Rangie
Scotland, UK
Alec,
These are far from stock over here, I'd like sizes so that I can be prepared without waiting for a week and a half until they arrive.
I have annealed washers in the past, but I want new in case any are damaged/distorted beyond use.
The largest "common" size stocked here is 22mm ID, 27mm OD and 1mm THK, I believe the 6.2 injectors are M24 thread so OD approx. 30mm? Anyone have definite sizes?
Thanks,
Alec.
Jozseph
New York
Thanks,
Alec.
Alec,
I located the following information;
M17 x 21 x 1.5 (BOSCH 2916 710 611, GM 14025557)
This is from;
http://www.nutandboltman.com/assortment-box-of-diesel-injector-washers-24409-p.asp
Review the link.
Regards
Joseph
Rangie
Scotland, UK
Hi Joseph,
I stumbled upon a similar link for an assorted kit.
Got a few today, I'll pull the suspect injectors and check the sizes! :D
Alec.
