injectors needed
AMGeneral
115
Connelly Springs, NC
Unless the holes in the injector tip are screwed up or the bolt holes in the head are fouled up all you need to do is remove the broken bolt.Then install the injector with new copper gaskets at the bottom and retighten the injector hold down bridge,making sure it is level and both bolts are torqued to the proper specs.
atilathehun
west edmeston ny, 13485
thank you amgeneral for the info and all the help guys i will be fixing the last owners mess there are 2 different grades of hardware holding them and 3 different lenths of bolts with washers as shims :?: the one that blew had grade 3 the rest have grade 8 in them but they are all leaking at the base of the injector. Would enyone know the torqe spec and what grade bolts to use and i would step torqe them correct. And again thank u
atilathehun
on the top of the injector there is a t for the return line they are set up like a regular compression fitting i am asking because one of the copper gaskets is missing on the t fitting and i was wondering if this was somthing napa might have thanks for the help
1,178
You can use a normal 1/4" ferrule, be sure to use a brass end tube insert also. Do not over tighten it.
zb39
PA
I have 3 injecters out also. Do you use any sealent when putting these back in ?? It looks like i have a little on 1 of them.
