Inline pump
rickdavis81
84
Rich Hill, MO
Went to start the truck today after a lot of work and spin on filter kits. Realized the intank pump doesn’t work and it’s not getting power. Double whammy. During my online search for a pump I found a lot of people saying the inline pumps didn’t have the gph to keep the engine happy. Has anyone ran the airtex pump bigmikes offers? Did it have enough flow? Would much rather go that route then a factory $$$ pump. On a positive note the block heaters in my tractor and skid steer still work. Had to set my bed back in place.
Elijah95
Certified Rookie
1,239
1,183
Georgia
I can tell you now, some people will vigorously defend the in-line pump, and some will even say “My in-tank pump has been dead for years and my truck runs just fine!”
The reality of the situation is a deuce can run for a long time without a lift pump, months, years, who knows just how long, but ultimately with no lift pump or using the in-line sucking against gravity to push fuel forward you’re slowly killing your injection pump by stressing the booster pump and hydraulic head causing excessive heat and wear. The injection pump itself relies on excess fuel to circulate back to the tank assisting in cooling itself.
Something else to consider, power will be down especially at higher rpm, I’ve experienced it in 3 trucks now first hand. A truck that’s already slow will become even slower. Food for thought, the design of the factory in-tank pump allows for robust reliable operation even when fed waste oil, dirty rust-laden fuel, gasoline and alternatives without much fuss, but an in-line pump has tight tolerances with no in-line filter. If your truck has rust in the tank like 99% of ours do, that pump will die from trash ingestion eventually.
Anyways, you can contact olympia direct and source a brand new, not NOS pump for around $350. I’m lazy, I’m also really cheap, but I hate spending money a 2nd time because I took a shortcut. Just my .02 with some experience to boot
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
I run a Carter pump as a transfer setup for my tanks. It pushes and pulls fine
P4603D is 24v @ 43gph.
P4389 is 12v @ 72gph.
Made for diesel. Just filter before it goes thru the pump.
rickdavis81
84
Rich Hill, MO
I understand the needing a lift pump. A lot cheaper than unnecessary wear on the ip. I only plan on clean diesel and a filter before the pump would be a good idea
simp5782
9,329
Mason, TN
Filter head 142784S is a cheap unit for single
Or 212013s is the same in dual head.
Cheap filters ranging from 10 micron separators , 20,40,140
FS1000
Fs1212
FF104
FF105
Lots of others. Even some heater element ones.
Computerdoc08
217
Florida
Do you have a contact for "Olympia"? I would like to inquire about a new pump from them if they have any available.
Godspeed131
931
Knoxville, TN
@Computerdoc08
I had one with the pump side gummed up that I thought was repairable so I sent out a email to Olympia www.occorp.com and they responded back with this
“The fuel pump you are referring to is our p/n 311389-1. We can supply a new one to you for $400. The fuel pumps are sealed so we are unable to fix them. If you would like to order one, please send your name, phone number, email address and shipping address to Matt, mscandora@occorp.com. We can then call you for the credit card number when it ships.”
I wound up disassembling it myself and cleaning it out and it worked perfect so far but I have a spare Parker pump on standby just in case. The above paragraph should get you what you need in contacting them. That email was last March so prices may have fluctuated since then
smoke
89
oxford,pa
Did you check the in-line fuse to see if its blown? Alot of times either the base plate falls off or the piece of rubber hose gets soft and needs replaced. Just pull it out and check it first before spending money that you can spend on something else.
rickdavis81
84
Rich Hill, MO
I checked it. Fuse was good just no power to it. I gave it 24v and made sure it had a good ground and still nothing. Got a pump ordered. Don’t have any lights other than headlights either so I’m suspecting a bad connection somewhere under the dash
