Inner Seals
FreightTrain
Banned
2,730
13
Gadsden,Al
Ok,Did a search but didn't come up with anything.How in the heck do you get that dang Washer/retainer/Plate/whatever out of the axle tube to replace the inner seal on the front end?
FreightTrain
Banned
2,730
13
Gadsden,Al
Dang.I was hoping I wouldn't have to do the bar thing.Just one more thing I gotta buy....Oh well.Scrap yard,here I come!Oh,and a 10Lb sledge....Hope I can clean the rust off the king pins and find all the parts.It has been torn down for about 2 years.Lost interest after I tore it up and couldn't get that dang ring out.When I tear something up I tear it up!Lets see,one night mud riding......Clutch,Throwout bearing,Pressure plate,Front bearings,seals,drums,pads,parking brake drum and shoes.........haven't even looked at the rear drums....Hope there is enough meat to turn them down cause I know they have scores.
ken
25
Houston Texas
If you can get a slide hammer bearing puller you can put the hook/fork in inside and give it a few wacks. They usally pop out pretty easy this way. Some auto parts will lend them to you with a deposit. Otherwise you can pull the other side apart also and use a long 1 inch bar to knock them out from the other side.
