- 2,102
- 28
- 38
- Delta Junction, Alaska
Several days ago, I had occasion to recover a M 989 Ammo Trailer. I took a "new to me", but also, new looking Inter Vehicle Cable, as well as a light bar, in case things didn't work. I ended up, using the light bar, but the issue was the inter vehicle cable. The trailer lights are perfect. It seems on the female plug end, the little sleeve in there has been pushed back into the housing on the tail light circuit (there is continuity in it), until there is just no connection. Question: Is the plug end repairable? I don't see how it might come apart, if it does? I have a spare 12 footer - the trailer only needs a 6 footer. if the plug is not repairable, that is a lot of cable to throw away. Has anybody found a way to repair these? Direction would be much appreciated! Thanks
