Inside rear wheel removal
fhu667
Dallas
I was removing my wheels today, and I ran into an issue. The outside rear wheel on my passenger side came right off. However I can't get the inside wheel off. There are no inner lug nuts. It appears that the wheels just sandwich together. I figure I'm not the first one with this issue, so I'm hoping someone here can help. Thanks!
gimpyrobb
dumpsterlandingfromorbit!
27,786
751
Cincy Ohio
You have to remove the "thimble".
Its the square drive that is still there. 13/16 square if memory serves me.
fhu667
Dallas
The square drive is still there, but I thought it looked like the wheel should slide right off. It wouldn't be the first time I was wrong.
gimpyrobb
27,786
751
Cincy Ohio
Nope, see the flange at the bottom?
Time to start reading(tech manuals) about what your driving. What would you do if you got a flat while on the road?
fhu667
Dallas
Thanks for your help. That makes perfect sense, but it just looks like that wheel ought to slide right off. Obviously it didn't.
Tow4
646
Orlando, FL
Here is an easy way to remember thread direction for removing the lug nuts. With the lug wrench on the nut and the handle pointing straight up, pull towards the back of the truck to loosen the lug nuts. This is true for either side.
1,177
No need to remember anything if you simply follow the step by step directions in the tm.
TGP (IL)
35
Metro East IL
Thanks DH !
Actually it was sorry excuse at joke.
I use the TM's faithfully.
However after over forty years of R&R Budd and Dayton wheels
The TM's need not be applied.
Tom
