Install front winch will not fit with brackets
86humv
493
Texas
1123 has a winch plate but does not have frame extensions which is needed for a warn electric
winch.......Milemarker hydralic takes a whole different setup.
juanprado
2,812
Metairie/La (N'awlins)
see this thread for instruction book. It has the mile marker part number along with military.
the above are excellent sources. If you need other widgits, i have been successful ordering directly from MM. I am not military and when I called in; stated I was a consumer with a surplus truck and used mm part numbers. YMMV
Don't ask me how I know but make sure you install the brackets to the correct side. Mine came in unlabeled with no part number and they will bolt up regardless to the frame but will not work reversed..........
