- 4,362
- 4,085
- 113
- Brentwood, Calif
Got it done...hardest part was getting the mag drill out and drilling 3 holes.
Also, toss the two 1.50in bolts...they need to be 1in or 1 1/4, probably made for the universal mount. I used the template.
At first on air up everything whet fine, but when I pressed on the brake pedal I had nothing and low air wearing went on, I cycled through a few times and it got better, even drained the tanks again, it was building pressure fine and all was a go, just mushy to the floor, then it cleared up and I took it for a spin...went through multiple stops, ebrake, drained the tank, did it again...seems good.
How hot is the dryer supposed to get?
The old one was pretty hot, this is just warm....
Also rerouted my old air lines, they were banjo string tight. There was no need to
Shorten or extend the lines, just rerouted and turned some fittings a bit so no bad angles. The only fitting I bought was for the control side, I got a 1/4in ODx1/4in MIP,compression elbow...got it at lowes, mfg watts LFA-30
