- 556
- 53
- 28
- Winston Salem NC
I thought I would document the installation of the LED taillight kit that fits CUCV’s from LMC truck parts.
Here is the kit; it has the LED array and pretty much everything you need.
Second picture is new taillight lenses...they make a big difference.
I first took the old lenses off, and then the light housing is held on with 4 Phillips head screws. Once you get the housing off you can twist the light sockets out.
Next you want to identify the taillight/stop light socket as it’s the only one with 3 wires: yellow, brown/yellow and ground wire that’s black.
Cut the socket off and strip the three wires.
While I had the light housing off I cleaned and painted it silver again, and cleaned the ground wire to the body from the wire harness.
