acesneights1
- 21
- 20
- CT
This is gonna take me a few days to post up...
So It's been awhile and I got a bug up my ass to finaly do the turbo swap. The radiator is shot and the bottom corner is rotted so if I gotta pull the rad...Might as well go all the way. I got the 6.5 TD from my 93 that went kaplooey. Biggest problem I face is mixing and matching heads. I was gonna just reuse the 6.2 heads and bend the inj lines a little with short body inj. I stripped the motor down to do the headgaskets first. Silly not to do them if I got the IP off and the manifolds and the coolant drained. So I get the drivers side head off. I clean it up and get my ARP studs all ready(the only way to go) The back stud by the brake booster won't go in the hole. It' hits the firewall. So I get the bright idea to whack the firewall with a 5lb. I only need like an 1/8 inch. well...I miss and hit the f'in valve. Blew the keepers right off and cracked the valve guide...
So I have one spare 6.5 head in my container from another motor that went kaboom. Guy in town here is selling a 6.5 head for 100$. I figure I'll use the precups from the 6.2 because the spare 6.5 head I have is square precups and the head I bought has diamond ones. The 6.2 have 3 squares.
well the 6.2 ones won't fit in the spare head I had. The dont sit flush. I'm like WTF ??
So I pull the heads off the motor from my 93(1 of those heads is bad but I don't know which one)That has round precups. I cant friggin win. 4 different heads 4 different precups. So I pop the round precup out and try it in the spare head I have. Still wont sit flush. I finally came to the conclusion that that head must have been decked. So I am going to use the head I bought and took a crap shot on which head I think was good on the other motor. One had corrosion around one of the valve and in the cyl so me thinks that was the bad one.
I got tendonitis and carpel so I can only type a little a night.
