installing a batt. disconnect switch
Kenneth Cole
42
Wapiti Wyoming
Hi
This I know is not new but I installed a disconnect switch today in my 1991 Humvee. I removed the slave connector from the passenger seat base along with its cables. Then using the connectors mounting holes made and mounted a plate to cover the hole and then drilled out the center to except the switch. Then I got 6 feet of 02 cable and terminals from a welding supply store. The switch that I used was from Jags P/N 10307. It's a beast and maybe overkill. The nice thing about this setup is the switch is recessed so you can't bump it with your foot and you can't easily see it for security.
Ken
Inspector 1
73
Spring Texas
Could you send some clear pics of the wiring for your disconnect switch. I tried installing one on mine and evidentially had it configured wrong. When I turned switch on it blew to Kingdom Come.
Thanks...
sue
346
tulsa OK
P.M me and we along with others are
not smart enough to post pictures.
But we have a not that noticeable
switch that was cheap and easy to
hook up.
Coug
4,311
Olympia/WA
Remove the battery cable that goes from the negative terminal on the rearward battery to the negative shunt (looks like 2 blocks with multiple thin bars between it, bolted to the side of the battery box)
(This is with 2 24 series batteries, but will be the same cable with 6t series, just find the shunt, find the cable that goes to the batteries, and remove it)
(And yes, I have a few extra cables in the box here for the BEOD I currently have on the truck)
Take battery disconnect switch, with 2 cables attached to it.
Run one cable to the shunt, the other cable to the battery negative (in other words, the two spots you just removed the battery ground cable from)
That's all there should be to it. Just make sure the new cables you installed aren't rubbing against anything, if the one connected to the battery shorts to ground it bypasses the switch and since it won't be a good connection, bad things will happen.
Thanks...
If it blew up immediately when you turned it on without doing anything else, my guess is you managed to wire it to both a positive and negative connection.
Not shown in my picture above is there is are several isolation bolts towards the front of the battery box from the shunt. Those are positive voltage, if you hook to one of them then ground you'll definitely blow the disconnect switch.
13
boise, id
Good thread. I've used similar devices on RVs and have always wired them to the ground side of the circuit. There are different schools of thought, however. If you wire it to the ground side like I do, then the switch itself is not at risk of shorting out to the chassis. For example, if you accidentally touched a piece of metal to the switch and the chassis, nothing would happen. On my RV, the battery and switch was on a storage rack and I didn't want to risk something metal touching if it was wired on the positive side.
Inspector 1
73
Spring Texas
Thanks for all replies and pics. Forgive me for my ignorance but you talk of a "Shunt". I'm assuming that this is the rectangular box on the inside of the battery box? If I understand you correctly I need to totally disconnect the negative cable that connects from the battery to the "Shunt". Remove that negative cable. Install the cable from the disconnect switch to the "Shunt". Install the other cable from the disconnect switch to the negative battery terminal.
Sincerely...
Coug
4,311
Olympia/WA
Sincerely...
Yes, that is what I am trying to say (sometimes words aren't really very good for explaining a concept, but I think we are both saying the same thing here)
Here is a little closer picture of the Shunt. The actual nomenclature in the manual might be different, I haven't looked it up.
It's a device that measures the amount of voltage drop over a gap with known resistance (in this case all those flat bars), then the gauge is what uses that voltage drop to tell you how many amps are being either charged or discharged through that shunt.
Inspector 1
73
Spring Texas
Thank you!! Got it!! I will reconnect at my 1st opportunity. Thanks again for all of your help.
Sincerely...
Mogman
9,510
Papalote, TX
Hi
Ken
I am assuming you meant JEGS, not overkill at all.
It appears to be a standard battery switch, how did you recess the switch?, pics would be nice.
Kenneth Cole
42
Wapiti Wyoming
Mogman
Hi
Yes , sorry I ment Jegs. The slave switch is located in the front of the passenger seat base. After I removed the slave connector I mounted the disconnect switch in that pocket. I had to make a plate for the switch to mount in. I hope this makes sense.
Sorry I don't know how to post pictures. If someone could help me with posting pics that would be great.
Ken
Coug
4,311
Olympia/WA
Mogman
Hi
Ken
For images you can drag the file directly to the text window, or you can use the "insert image" button (right next to the smiley face button at the top of your text input window) or press "ctrl + P" to bring up the insert image box.
Casasenita
Ohio
Tell me if I am correct... If you use a solargizer on your batteries and install the cutoff switch, the solargizer is taken out of the loop and is ineffective when the cutoff switch is in the off position.
I have a solargizer and would like a cutoff, but it seems counterproductive if used together.
osteo16
585
Evansville, IN
Correct on the wiring.. always interrupt the neutral side of the power loop..that way the disconnect (switch) can never get shorted to ground.. but on a different note, will a disconnect switch hurt my ESSS in any way ? Just wondering with current being switched on and off.....
Ocho out
86humv
498
Texas
I put a temp cutoff switch , but left the slave plug live, so I can attach a charger without turning switch on.
