Insulation behind m923 seats
fpchief
220
South Alabama
My cab Insulation behind the seats is pretty shabby. Has anyone found any locally sourced insulation that works decent? I re-insulated the hard top in my deuce with iso-mat (sleeping mat) but those things get expensive.
Hammer
396
Winlock, WA
Another lost cost item I like to use is window flashing from Home Depot, Lowes, etc.
Get the aluminum backed stuff, something like this. Repair tape - Home Depot
I like to make sure the metal is dry and WARM. I like to use a little propane torch to heat the metal, then after applying the rubber flashing, I lightly heat that some and roll/press it on.
This stuff is cheap, and works GREAT for sound deadening panels. Around firewalls holes, floorboard holes, etc. for sealing up holes, drafts, etc.
Also, works good inside door panels to take out some of the metal / tinny sounds.
Buffalobwana
177
Frisco Texas
If you still have the original insulation, try the 3M spray adhesive for headliners. be generous with the application, and hold/press it in place afterward.
Ventilation is a good idea as its quite strong
