intake manifold oil aspirator, injector.
nathanto
La.
Do any of you remember the glass bottle mounted in the engine compartment? I think that marvel mystery oil was put in the bottle. Then the vacuum from the engine would bubble the oil, and inject small amounts into the intake.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Of what?
I think you are getting some of your memories crossed.
There were oil bath air filters for old motors and there was aircompressor anti-freeze which was a bottle of alcohol. Are talking about either of these?
nathanto
La.
I noticed this contraption a few times on vintage cars, and trucks. I had a name that I cannot grasp right now. I think it was called an aspirator, or something along those lines. It was a specific device used to lube/clean, the intake system, and clean the combustion chamber.
nathanto
La.
I have to agree this may not be a military application. But when you want to find something. Ask a pro.
plym49
171
TX USA
Of what?
Maybe one of the resident old-farts can enlighten us!
You rang?
There were indeed top oil injectors for upper cylinder lubrication. They used engine vacuum to pull in a light oil, typically MMO.
There were also firewall mounted glass w/s washer fluid bottles. And oil bath air cleaners. And alcohol-water mixture bottles to control detonation on early turbocharged engines (pre-electronic controls).
There were even firewall-mounted vacuum fuel pumps that used vacuum to refill a cistern that would gravity feed to the carb.
All of these were separate things.
nathanto
La.
Thankyou for the replies. I found one after some searching. I found a kit, made by Marvel. It is called an inverse oiler.
