- 142
- 35
- 28
- Los Angeles, CA
I'm not sure if I have an issue or one developing.
I have an Alt 1 light that sometimes doesn't light when I start the truck.
I've had the dash off and cleaned the contracts with an eraser for the plug and connection to the lamps. I've cleaned the lamp plug also. I believe the contacts to be good. The bulb is good.
I cleaned the ground on the driver's alternator.
The front battery is charging between 14.0v to 14.1v. The rear battery is 14.3v to 14.4v. I can hear the belts squeal when the glow plugs cycle. The gauge is normally where it shows it's charging. Batteries are about 1 yr old.
Is this a problem that's forming in that the alternator is beginning to die or am I missing something?
