Drock
- 12
- 0
- Eatonton GA
Okay I'll try and make this short, but I want to explain it all. I changed the trans fluid, and swapped the pan out for a after market deeper one. The gasket that came with the new pan failed spraying trans fluid EVERYWHERE! So I degreased the whole underside of the truck, Installed a new gasket. And now no more leaks. While all this was first going on I was smelling hot trans fluid and sometimes when I would put the truck in park , then back into drive it wouldn't go into gear without standing on the gas! I figured these issues were both from the leak. Once moving it was fine....... So now that I've fixed the leak I'm still getting the hot trans fluid smell and every once and a while it won't go into gear from park? I used (Valvoline Max life) fluid which says it's DEX III compatible.
