Changing the hydraulic head is a pretty simple "by the book procedure".
The R&R procedure of the hydraulic head for the ld, ldt and lds are the same.
This was posted by Bjorn on Oct 11,2007
For your LDS465 engine, basically:
1) Remove the steel lines to the injectors
2) Remove the cover for the fuel cut-off mechanism
3) Remove the fuel cut-off lever (be careful with the "tooth" at the end which is loose)
4) Turn engine over manually until a scored gear tooth (may be marked in red) is lined up with a pointer visible when the fuel cut-off lever is out of the way.
5) Remove all fuel line connections and 4 ea nuts clamping the hydraulic head.
6) Pull hydraulic head straight up, you may have to tap it lightly. Reverse procedure for installation.
I just finished working on mine and it's pretty fresh in my mind.
TM 9-2910-226-34
