ip pump
wharfman
isle mn
i have a m54 leaking fuel in oil going to try to replace o ring on hydraulic head
on ip pump can some one tell me how it comes off or do i have to take the ip pump off the motor and what tm shows how to do this?
thanks for any help dave
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Is your FDC by-passed? Many have found that is the source of their fuel in the crankcase problems. Before I tried to swap out the HH O-rings, I would do the bypass.
wharfman
isle mn
can some one tell me what im doing wrong lined up timing mark unbolted hydraulic head assy but can not get it to pull off what am i missing
thanks
gimpyrobb
27,785
748
Cincy Ohio
The timing mark only gets you close. You need to line up the red/scored tooth that is under the engine kill pully thingy on the side of the IP under the HH.
PM sent.
