jdeoliveira74
- 2
- 0
- wilmington nc
I have questions about the removal of the injection pump. I have disconnected the fuel injection lines from the injectors and the three bolts from the injection pump. I removed the oil filler neck and i see a bolt but not sure if I should remove it. I figure it has to bolt in somewhere in there since it does control the timing just not sure! Don't want to mess it uo!
