IP throttle shaft seal replacement mistake?
welpro222
Bellingham, WA
Well I was working on replacing my throttle shaft seals and when I was trying to remove the guide stud holding the min-max spring, the allen head broke. Now I can't remove it? What r my options if anybody has experienced this?
Chaski
56
Burney/CA
RuhRoh...
Can you get any sort of pliers on the rod with the lid removed? I have a bunch of injection pump parts if you end up butchering parts getting it apart
bchauvette
12
Easley SC USA, 29640
General broken screw removal advice......
Can you cut a screw driver slot into the broken stud with a Dremel tool and a thin cut off blade? Possibly cutting into the surrounding area for a full slot in the stud.
welpro222
Bellingham, WA
I ended up putting a rebuilt pump in and boy what a difference in performance, I guess the leaky one was getting tired. Starts right up hot or cold and runs great.
cucvrus
10,348
Jonestown Pennsylvania
Yes that is the only way to go. Seems to work every time I have problems. It is a lot less frustrating and inexpensive to just replace the defective pump. Sooner then play try this try that and still end up replacing the pump in the end.
