Is a dual radiator cooling fan really that helpful ??
Sverige
VA
I need to replace my M1009 radiator cooling fan, which was jerry-rigged by the previous owner. I noticed LMC sells a dual cooling fan and was wondering if it's really that helpful. Any insight would be appreciated.
rsh4364
15
greensprings ,ohio
I would throw a coolant temp. gauge on it,upgrade if you have to.Generally with stock setup they run pretty cool.What don't you like about current setup? You can always rewire.
Sverige
VA
To be clear, I'm not upgrading. I need to replace the existing jerry-rigged contraption, which includes a manual switch in the cab to turn it on and off. I'll either put an original back in or this cool dual fan electric model LMC is selling.
All comments are welcome.
hovenga67
Evansdale/IA
The best way to do it is get a shroud and clutch fan. I tried a dual fan setup and it didn't run any cooler. Also I had problems with the relays burning up because of the current load. I switched back to a clutch fan and like it better.
hovenga67
Evansdale/IA
Also some of the stuff lmc sells is cheaply built. I don't know about this particular item but just letting you know from my experience buying stuff.
Csm Davis
381
Hattiesburg, Mississippi
Not sure about the LMC version but I have been wanting to convert mine to electric for a couple reasons one free up a few hp and two to allow me to turn it off if I am in deep water and yes I go there once or twice a year. I have seen a twin fan with a shroud that looked good not sure who made it but that would be a big thing for me as I use this truck almost daily.
southdave
ripley, oh/TDY Lordstown,Oh
I have derail twin fan controller in my 1009 4bt set up ... it is nice , each fan can have it own set point depending on the coolant needs. Mine fan 1 kicks on 180 fan two 200 .
Also feature if fan has two speeds.. cummins run alot cooler than v8...
V8Astro
StL/MO
Clutch fan will outflow any electric fan that would fit. For a CUCV that's the best way to go IMHO. Electric fans are used on new trucks solely for emissions / efficiency reasons. I've used them in the past on hot rods where throttle response was important. Doesn't really matter on the old 6.2
