- 2,883
- 1,490
- 113
- Czech Republic
I have to check the front brake cylinders and brake shoes. Is it possible to remove the front brake drum without the hub or do you always take of the entire hub as per TM ..20? Sounds like overkill to me because you start messing with the bearing automatically, which I always try to avoid. I tried to loosen the bolts securing the drum but could get no movement in the drum, which should at least come forward a bit. Any trick there?
