10Lugger
- 5
- 18
- White Post, VA
Cold weather is here and last night my rear tire went flat. I let the ctis air up the tire then took a spay bottle to it and found the leak at the screw adjustment at the angle valve. I turned screw and deflated tire. I disassembled cap and found valve and o-ring. Looked for info with no luck. Is this serviceable? Number 13 on TM.
