Hooty481
- 4
- 18
- Russell County Kentucky
Is there a difference in between the white multifuel and the Hercules Multi fuel?
All the 465's have the same specs However there are, or at one time were different sizes that worked with the multi-fuel engine.
The size that are standard are called N-50, When stationed at Ft. Leonard wood I had the great privilege to meet and become real good friends with a retired Chief Warrant Officer That had sent 33 years in the Army first going from Private to Sargent Major, then up to Chief Warrant Officer 4,
He hooked me up with N-80 injectors, we turned up the fuel, and removed the Governor, the truck would run 70+ on 900's with little problem.
I did this to a truck I had in Germany and would go up some of the mountain roads in 3rd gear when everyone else had to reach down to first to climb.
Not sure if the N-50's can be found now or not, or where to even look.
there are/were different injectors that worked for the Multi-fuel engine.
Not sure I would run bigger injectors on a truck I have to depend on getting to home at the end of the day though!
