- 5,580
- 2,861
- 113
- Metairie/La (N'awlins)
I had to have my m923 towed due to throwing off a water pump belt on a narrow long interstate bridge.
I am attempting to reinstall the drive shaft from transfer case to forward rear axle propeller shaft.
I am using tm 9-2320-272-24-1, Para 3-150, pg 3-417
I am having trouble sliding shaft #7 (I would call it the yoke) to shaft #9 ( splined drive half shaft?)
I see an alignment arrow on yoke #7 but no markings on splined shaft #9 and driver did not mark or paint when he dis-assembled
Is there an alignment grove on one of the splines as I have tried sliding them together into each other and can only seem to get them 1/8 of an inch into each other? How do I identify it?
Thanks for all your help with a newbie on a 5 ton driveshaft!
