Rik
- 37
- 18
- California
I have an MEP804B Genset. I have some items at my shop wired for 220v 3PH and some items wired for 440v 3PH. When I need to switch between the outputs I have to open the panel door, remove the 12 nuts on the panel plate and change it's position and rear attach 6 nuts and reassemble the protective plastic plate and so forth each time.
Is there possibly a way that I can wire a switch that I can merely flip/rotate/move to make the output switch between the 220V to 440V easily and quickly?
