Is this radiator salvageable?
Katahdin
24
Scarborough, ME
Well, I set out today to flush and remove the radiator so I could refab a new shroud that runs along the bottom of it. Bad news is I didn't expect the radiator bolts to shear off and well, the the bottom radiator frame doesn't look all that great either. Is this radiator toast or is it worth trying to refab the frame and bolts?
I have the metal cutting tools, but only had a Mig welder for a week...I wasn't planning of refabing anything of this complexity for awhile. I'm afraid I'd ruin it for sure. Do radiator shops do this work?
wreckerman893
Possum Connoisseur
15,626
2,037
It is getting harder and harder to find an old school radiator repair shop that will repair rather than try to sell you a new or rebuilt radiator. Considering the cost of a new or remanufactured one I would hunt for one.
Some NOS radiators sold off GL a while back....I don't know if anybody here got any....you might post an add in the wanted section.
5ton4ever
vacaville ca.
If the core is good them I would repair it myself. I wouldn't pay a radiator shop to try to fab the new bottom mount. Maybe a sheel metal fab shop could make the lower mount that is corroded. I repaired one in a 66 deuce that had the bolts corroded off just like yours. wasn't real pretty, but who sees it? It also depends on how much money one wants to spend. Good luck.:beer:
Katahdin
24
Scarborough, ME
Thank you gentlemen. I'm exploring replacement options but still hope to fab a fix for it eventually. I believe the core is good, my time and fab skills just aren't where I need them to be yet.
That said we do have an old radiator shop in town, I'll bring it by on Monday for a look see anyway, it'll probably be a good conversation piece. :wink:
rchalmers3
30
Irmo, South Carolina
..... I believe the core is good, my time and fab skills just aren't where I need them to be yet.
This seems like a "right sized" project to build your skills. It's thick metal, low tolerance work that will save you money if you chose to DIY (and the core checks out).
Rick
tm america
23
merrillville in
You could go to a place that sells metal and does fab work to have them fab the pieces so all you have to do is cut the thinck piece and weld the new to it..For the cost of a new one it's well worth trying.. If you aren't happy you end up getting a new one if it works you save like 700 bucks:driver:
