Is this supposed to be blocked off?
Lonesome715
24
Columbus, GA
My air cleaner housing has been sitting in the back of the deuce for a while in pieces. As I was cleaning it so I could re-install it I noticed this fitting was clogged. I figured the dirt dobbers did it because they have been wreaking havoc on this truck. When I tried to clear it out I found the blockage was metallic. I am assuming this in the fitting that connects to the line that runs to my air filter indicator on the dash. How does it work if it is blocked like this?
DieselBob
13
Arnold Maryland
Well that is the fitting for the restriction line. Looks like someone didn't remove a broken piece of an old line. Not sure how they managed that seeing as the line should have been a flair fitting. Depending how completely that blocked the fitting it would cause anything from the indicator not working to working very slowly.
Motorcar
San Antonio, TX
I don't have one like that on mine, don't recall seeing on some others either, part of a fording kit?
Disregard what I just said, ran out to the truck and there it is as DieselBob said...line to the restriction indicator mounted on the dash. Sorry, I'm obviously short a cylinder tonight.
1,806
Why is it blocked off?
Unless one of us was at the shop when they plugged it, I doubt that anyone will be able to tell you why. I know that the air cleaner restriction gauge won't work with the obstruction. Clear it and call it a day.
combat32
106
Booneville AR.
The Army quit using air restriction gauge years ago, we quit writing them up on 2404"s about 20 years IIRC, it's kinda useless anyway if you service your air cleaner as per -10
SMOKEWAGON66
21
California
I concur with everyone above...its the fitting for the air restrictor gauge. You dont need it. Its not vital...nor were any of the ones I ever saw even close to being accurate. Just leave it plugged. Aint gonna hurt or hinder anything, and wont improve perfermance or looks if you unplug it....your call.
Lonesome715
24
Columbus, GA
I was never a fan of them either. I would like for it to work simply because it is on the truck. That blockage is in there pretty good, it looks like I will have to drill it out. The line that runs to the gauge is clogged as well. Just at a glance it looks like the work of dirt dobbers though.
WillWagner
2,532
Monrovia, Ca.
Restriction and starting fluid fittings have a "rock" filter in them, that way if the restriction gauge or the line from the starting fluid can breaks, falls off, has been forgot to be installed, whatever, the engine doesn't get filled with dirty, unfiltered air. Remember, the flow will find the path of least resistance. The rock filters make it so the path of least resistance is the intended inlet, the air filter.
phil2968
17
Lakeland, Florida
You beat me to it Will. One good way to clean that filter/fitting is to use carb cleaner and compressed air. If you can blow air through the fitting/filter with your mouth it's clear. Try it and see.
Lonesome715
24
Columbus, GA
I did not know any of that. Considering this truck will never see combat and, it is not likely to see any real off road abuse, I mat just delete the whole thing.
