ist shots for armyman..
1,127
Wow!!!!!! That looks great! You almost don't even see the Jeep in the back of the cargo truck!
WillWagner
2,574
Monrovia, Ca.
Cool, that IS a jeep in the back of the carco truck! How did you get it in/out? Did you know you're drivin on the wrong side :wink:
dmetalmiki
2,027
London England
AAAA! HA! gents....would yo b leev "one at each corner and heave??" NO? quite right..now IF U look (ever)so more closly you will see the "ramps flap" (deuce has same!) if fact I'll mark a photo 4 YOU all (then THAT mod can b carried out if u want to!)..and SHUCKS!! IZ that WHY everyone honks at me ALL the time!!..the reason I'm lined up there iz...see pic 2!!
rockman
Kingsport, TN
looks like singles on your trucks
with the singles, did you flip your hubs and if not, any bearing wear issues...
Let's see the scammel...
Thanks, Bill
dmetalmiki
2,027
London England
RE: looks like singles on your trucks
The deuce IS flipped...AND the front wheels also kicked out 4" as I cant abide that crab look UNLESS they ALL track one behind the other.
also the deuce is on 1200x20 with adaptor plates I made. low revs high speed..good steer. NO bearing issues.(loading of bearings within decent bounds) properly adjusted= O.K.
the five ton is NOT reversed AND the fronts are kicked out 5" so they too track one and the same. No bearing issues . loading (well!) within bounds. same applies. I will post pics of the trailer when I get it..(soon!) not sure bout the D.Tee..Me thinks I really am over tasked..ho hum..pity bout me b...ering up the scammell..see what I mean about over tasked?..just one meestake..and.."CRUMP" 3 (yep folks THREE) grands worth O' damij!!..((kiks self round the yard AGAIN!).funny but that DINT' fix it!..sighhh..NO,, BIG sighh..(and) sold "as is"
WillWagner
2,574
Monrovia, Ca.
"ering up the scammell"...".."CRUMP" 3 (yep folks THREE) grands worth O' damij!!."...dmetalmiki, you lost me man!
dmetalmiki
2,027
London England
sorry ..difficult if you havent follwed the "saga"..I had no help and in a flustered state forgot to put the scammell tank transporter into neutral on xfer and neutral between 1st and 3 rd.. result? after towing 5 miles? gearbox siezure!!..BUT can u (begin to) imagine the saga having a 30 ton tank transporter stuck on the highway??..well the M62 wrecker pulled that vehicle "screamin" OFF the highway!! ALL 10 wheels locked!!.. so now I have it back home and "sold" as is!.I have to say the M62 is the BEST vehicle I now own!.......GREAT in every respect.....((looking 4 a diamond T))
ARMYMAN30YearsPlus
Parkville, MD
Thanks for posting the pictures, the trucks look great. It is nice to see the US Army trucks in the English countryside. I bet there are a few older folk there who remember the days of WW II when it was a common sight. I hope to get my M52 running like your M62 since mine did a lot of screaming hauling my M127 with the brakes dragging a bit.
TacticalTruck
Va Piedmont
I think you've been playin' with Uncle Sugar's trucks a bit much...aren't you on the worng side of the road?
Jeff
OSO
Arlington,Wa
I know how it feels for an old friend to leave the nest.Looking at all of your other Iron you should be quite occupied. :( OSO
Cdub
New Milford, NJ
I was kinda surprised to see the wrecker driver attached the Under reach to the
bumper (frame ends) and not under the axle........??
I know it's a designed vertical lift point but with an under reach wrecker...??
any ideas on the matter.....as I will be looking to have a M939 towed at
some point or another.
seya,
C'dub
