ISU 90 Storage Container Question
honor first
21
NC
All,
I purchased an ISU 90 from GP. Not the exact unit below, but same thing.
My unit has the divider wall in the middle. I can't tell from the pictures, but is the divider wall modular, in that it can be removed by removing hardware, or is it relatively fixed? The AAR website and catalog talks about the interior walls being optional with multiple configurations, but doesn't speak on whether those walls are removable or not.
Need to know fory placement and site prep. If it is, I'll put it one way on the yard. If not, the other (less desirable) way.
Thanks!
honor first
21
NC
Didn't know there was TM for it, figured that was only a vehicle thing! If it does have one and you know the number, let me know, would be greatly appreciated
Guyfang
27,137
Burgkunstadt, Germany
Everything in the Army has a TM. I seem to remember there being a data plate on the ISU-90 , and it had a TM number stamped on it. I helped depose of a bunch of them in 2008 or 2009. And new/refurbished ones had the TM taped to the inside door. But its been too long for me to remember what the number is.
crallim
Manawatu, New Zealand
All,
Thanks!
The wall across the middle is plywood held in place by aluminum channel sections. If you can get the rivets out then you can remove the wall, but then you won't be able to fit shelves or dividers.
zebedee
conceptualizer at large
894
Central NY
I have a load of the clips that fit into the tracks that hold up the shelves. They 'look like' the brackets sold in hardware stores but are not the same hole spacing. Shelves are just plywood with aluminium angle aroung outside.
