It lives sorta....
FreightTrain
Banned
2,730
13
Gadsden,Al
Went and helped wrecker with his wrecker today.He drained the......stuff in the crank case.about 13-15 gallons of.....Stuff....We refilled it with clean oil,Drained the fuel tank(Ummm,wreck.what EXACTLY was in there?) and refilled with something that had a brownish color with a slight green tint and smelled like diesel.Fired it up and it runs but it now sounds like a steam locomotive.My evaluation is it ate a valve when it ran away.Still runs smoothish but has a very pronounced CHUFF CHUFF CHUFF out the stack.Figure it floated a valve and smacked it with the piston.But it is mobile again.we didn't change the O rings.Wanted to see if we could get it running first and it runs ok enough to move to the Alternate LZ I hope.He is looking at buying a 400 cummins with a 9 speed from a cab over Ford.
wreckerman893
Possum Connoisseur
15,623
2,027
After FT left the AO I just had to take the beast out for a drive.
Cranked her and let her idle for a few minutes and then headed out to warm her up so I could put in some coolant.
I got out of the driveway and took a right at the stop sign since that road is closed for bridge repair. I got her out of low range and fell into a banked curve.
NOTE TO SELF..........YOU NEED MORE THAN EIGHT GALLONS OF FUEL IN THE TANK FOR A TEST RUN ON A BANKED ROAD.
She died right in the middle of the road in the middle of a blind curve.
I called the CP and my son brought the rest of the fuel I should have pumped into the tank in the first place.
I drove her several miles and finally got the temp up and added the anti-freeze.
Backed her into the yard and almost sunk her in the garden.
She is now biding her time waiting for the next outing which will prob be the move to the new LZ.
The new shop will have doors big enough to actually get a MV into.
2,420
Golly gee whammo Batman. :roll: Either the wrong fuel or none at all...when will we get it right.:?:
BTW...the 400 *cummins* only likes diesel to. Thinner etc...etc.. will make it sick as well.:evil:
timntrucks
Ponchatoula LA
well at least now you have one running truck. if you had a bolster trailer you could haul all kinds of stuff at one time. haha. hope your move goes well. will she let you take all of your clothes?
