white135
- 0
- 0
- Auburn, IN
but not for long.
After all the hard work the last month or so, we finally got to try to start the XM215 today. It last ran four or so years ago, before being parked in the junkyard.
After several tries cranking, with no firing, the problem was diagnosed as dirty points by Ron of MV R&R, (never mind the need for the ignition switch to be on,
which I did figure out myself), the points were cleaned and it fired up.
However, due to an apparent air leak at the base of the carb, which is yet to be fixed, it wanted to run full throttle, so had to be shut off after ten or so seconds at a time.
However, It had good oil pressure,
air pressure was building, and the batteries were charging. It sounded great, if a little loud due to an exhaust system that is full of holes, but that's another project.
Eric
Eric
