motormayhem
- 6
- 18
- Tucson, AZ
How much does your trucks temp fluctuate during regular driving and up hills? Mine bounces around in the range of 180-190 but as it has gotten hot out (mid to upper 90s ) it has gotten to 195-200 doing 50Mph up hills. I just replaced the water pump, fan clutch, had the radiator cleaned out by a rad shop and it still seems hot hills to me at least. What do most peoples gems go between? How much does it fluctuate while driving? If I let the truck sit idling it drops to 180 but if it gets up to 200 it takes a while to start dropping. Gonna try some prestone flush to
tomorrow as my coolant is always rusty.
Also is there supposed to be a valve on the heater core hoses? Mine is running hot water through it all the time which seems lime a lot of water bypassing the radiator and possibly contributing to the problem.
