its a m32a2c?
goodguyzy
13
medford oregon
A few weeks ago i asked what this truck was, here are the pics off the data plates.
this is what i do know:
its a non-turbo diesel
was not overhauled
it was a fuel service truck
modified to carry water
used by USAF
plans are to part it out, everything leaks except coolant and water tank, will put up on classified ads when i do.
fuzzytoaster
3,114
Fort Worth, Texas
The plate says M35A2C but its been modified by the fire department or air force, as you said, with a tank which looks to be welded directly to the bed. If it was designed to haul water it would have a data plate saying M50, M50A1, or M50A2. Neat deuce. I bet her white paint gets dirty quick with no turbo! :D
jimm1009
71
Louisville, KY
It does indeed have the C style bed.
Hinges on both side and the rear are only on C beds.
They may have the removable sides and tailgate too if you poke around.
jimm1009
rlwm211
Guilford, NY
The cab and bed is a M35 but whether it has a turbo or not sort of has to do with when it was rebuilt and all that. The truck looks decent. I am sure you can probably replace the bed with a good take off cheaper than you can remove the tank and clean up the welds and find all the parts and pieces that are missing.
RL
goodguyzy
13
medford oregon
after reading your responses, i see that it is an original bed with a water tank installed on top of it, the rails are long gone since this was the 3rd or 4Th fire department to own it. I'm glad i didn't live in the town this truck was serving. your house would be long gone by the time this truck got there.
here are a few more pics of the interior
NDT
6,459
Camp Wood/LC, TX
Looks to be a very early USMC dropside. Marines were the first to have the dropside bed. Bit of a shame to part it out.
goodguyzy
13
medford oregon
yes its a battery cut off switch, to start it you must switch three things, the auxiliary power (now a key) the big "goofy" switch and another that is for the after market lights on the tank. as for a response on parting it out is this: i want the front leaf springs for a bobber, (saving me $600) selling the front and a rear axles for a toyota project (not mine). cab i need for another deuce with rust issues but everything else is in good shape. the motor, tranny... etc. is leaking so bad they need work. time and money that i have little of. since i have $1300 into the truck, so i will make out well in the end. hopefully. if anyone has a better idea, im always open to suggestions.
