It's all in the timing
CGarbee
552
Raleigh, NC
Bill's info on how to time a mule is dead on, unless you have one of the A5's that was converted to electric start at Ft. Campbell in the mid-eightees... They have a different pulley, so you have to set them by looking for the marks on the gears, and you have to set them offset one tooth...
Bill, NickD, and I, spent a fair amount of time on the phone about a year ago figuring out how to time my Mule... :)
Good luck.
Charlie
Alabama
The best way to check the timing is exactly the way Bill shows on his web site. If your belt guard is missing, you don't have any timing marks, but you can still tell if the mag "clicks" when the crankshaft pully mark is in about the 2:00 position.
To answer your orignal question, yes, both gears have V marks on them. Set the magneto gear one tooth to the left (clockwise) of the drive gear. Oh, I forgot, you have to remove the governor and the governor drive coupling to be able to se the gears and the marks.
JDToumanian
14
Phelan, CA
I wasted a lot of time before installing my magneto yesterday.... Trying to figure out it's proper orientation, and proper plug wire connections. Instead of staring at it and pouring through TMs, realize (like I did after about 2 hours) that the magneto fires for BOTH cylinders simultaneously, for every revolution of the magneto gear. That means it doesn't matter which plug wire is connected where.... Either wire can go to either terminal on the magneto. Maybe that's obvious to most, but it wasn't to me.
Here's a related question...
Why does Bill Watson recommend setting the magneto gear clockwise one tooth off, and the timing to between the 18 and 28 degree marks? The TM shows the timing gear marks lined up and the timing set to 3 degrees static which should be 18 degrees over 500 rpm.... I set my timing per Bill's website, but thought about it later. There must be a reason, even if it's something as simple as being able to remove the plug wires without removing the magneto, since with it set per the website the magneto is turned so it's terminals are more accessible than if set per the TM.
My engine is now finished...... YAY!!! 8)
Jon
1,131
I can't answer your timing question Jon, but I have to say, that's the nicest Mule engine I have ever seen. If the rest of the Mule is that nice, you need to take it and enter it in the next MVPA National Convention.
rod
Alabama - The Heart of Dixie
Jon,
If you set the engine timing according to the TMs, the mule will run Ok. If you set the timing one tooth off like it is shown on Bill Watson's website the mule will have a lot more pep and run better. a couple of years ago, myself and Chuck (aka Charlie here on this site) took our tools to a swap meet. We retimed 5 or 6 mules that weekend at the swap meet. When we finished a mule we would put the owner on the mule and ask him to take it for a spin. We could tell by the smile on their face as they pulled back up that they were happy with the extra pep of the mule engine.
JDToumanian
14
Phelan, CA
Thanks for the explanation Rod! I figured the reason must be to run it a bit advanced for better performance.
Thanks for the compliment Clinto! It's funny how projects evolve... Originally I was just going to "get it running." Then when I found the original engine seized and full of water, I was going to "throw in a genset engine." The new genset engine was so nice I decided to 'detail' all the parts I put on it, and carefully straightened, sandblasted and painted all the sheet metal pieces. Then I decided the entire mule deserved that treatment, so it has turned into a full blown restoration. I'm sure it will be nice but I never thought of entering a contest.... Intriguing idea...
My progress has stalled a bit, I've become bummed that I can't find the rear engine guard and engine hatch cover. I was going to have everything finished for Tower Park in April but I haven't even been working on it. :cry:
Jon
Charlie
Alabama
You've picked probably the two hardest parts to find! Bill and I have discussed building repordiction engine guards, and that's still ongoing.
I was buying the M274A1 guards from Bill and modifying them to look like A5 guards, but I think Bill's out of the A1 guards now. Here's the last one I modified.
I'm going to go look at a pile of mule stuff next week and I'll let you know if I find an engine cover and/or guard.
Charlie
Alabama
The mule "parts" that I went to look at turned out to be a pretty good looking A2. I've decided not to part it out, but will put an engine in it and get it running later this summer when I get a break from customer work. Sorry!
1,131
Since Bill's site is now gone, I captured these images and texts from an archived copy.
STEP 1: Remove spark plugs and find 28* & 18* (see pic) on belt schroud
Turn fan drive pulley clockwise(much smoother and precise using a crescent wrench) See Pic
If you hear the magneto click in the area shown in the first Pic you are OK.
If you do not hear clicking in this area then proceed to STEP2.
Step2: Remove the top engine schroud
Step3: Remove the spark plug wires from the magneto
Step4: Remove governor and turn engine "clockwise" until you see a "V" on the large gear. STOP at this point.
Step5: Remove magneto from engine. Holding magneto in left hand, rotate magneto drive gear "clockwise" untill you hear a click.
Step6: Insert magneto back into engine (see pic 4) for proper place to insert magneto into large gear.
rotate fan drive pulley clockwise (see first pic) and rotate magneto in engine until magneto "clicks"
YOU HAVE NOW TIMED THE ENGINE!!
